Clear ARP Entries
Use this procedure to clear dynamic ARP table entries associated with the interface or VLAN.
Clear ARP entries:
Switch:1> enable Switch:1# clear ip arp interface gigabitethernet 1/16
Variable definitions
Use the data in the following table to use the clear ip arp interface command.
Variable |
Value |
<1-4059> |
gigabitethernet|vlan |
Specifies the interface type. |
{slot/port[/sub-port][-slot/port[/sub-port]][,...][slot/all][all]} |
Identifies the
slot and port in one of the following formats:
